Oil light on dash...
Posted: Thu Aug 08, 2019 1:36 pm
by Gavla
My oil light on my dash board has started coming on once I have been driving for more than 20 minutes...
Full service with fluid changes in March this year...
What should I be looking out for?
Re: Oil light on dash...
Posted: Thu Aug 08, 2019 7:18 pm
by BenHar
First thing is to check the oil level.
Ben
Posted: Thu Aug 08, 2019 7:41 pm
by steve_k
first things first, what engine???
Posted: Thu Aug 08, 2019 10:55 pm
by arrisbmw
yes as above oil level, but i,d say dont drive the car untill sorted.
could be as simply as a faulty sender unit.
blocked oil filter .
blocked engine oil ways .
faulty oil pump , not likely
Posted: Fri Aug 09, 2019 9:30 am
by tha881
Im pretty certain the light on the dash relates to oil pressure rather than level
Posted: Fri Aug 09, 2019 9:33 am
by steve_k
tha881 wrote: ↑Fri Aug 09, 2019 9:30 am
it does,
Posted: Fri Aug 09, 2019 10:06 am
by Gavla
steve_k wrote: ↑Thu Aug 08, 2019 7:41 pm
325i
by Gavla
correct, oil level fine
Posted: Fri Aug 09, 2019 10:09 am
by Gavla
Ordered a new oil pressure sensor...just in case
Ordered 5w40 Magnatex to do an oil change...just in case
Ordered a crank case breather hose...just in case
Posted: Fri Aug 09, 2019 10:36 am
by paultv
I should say the oil will be at running temp after 20 minutes driving- it takes a while to get fully hot - stick some cheap 15-40 in and see if that fixes it (this is the oil BMW originally recommended for a UK climate) - could be a worn pump or simply worn engine... but hopefully it's the sensor!
Paul
Posted: Fri Aug 09, 2019 11:20 am
by Gavla
paultv wrote: ↑Fri Aug 09, 2019 10:36 am
...could be a worn pump or simply worn engine...
Paul
Simply worn engine...
Fingers crossed it is the sensor...
Posted: Fri Aug 09, 2019 2:57 pm
by BenHar
It does, but if the level is low the oil pressure light will come on.
Ben
Posted: Fri Aug 09, 2019 3:16 pm
by Gavla
So I changed the oil pressure sensor and changed the oil and it seems to have done the trick... fingers crossed it is not a temp fix...
Crank case breather hose will be a bonus, current one is brittle so probably needs to be changed anyway.
Posted: Fri Aug 09, 2019 3:17 pm
by Gavla
BenHar wrote: ↑Fri Aug 09, 2019 2:57 pm
Ben
This I did not know, thought only the onboard light would come on...
Posted: Fri Aug 09, 2019 4:57 pm
by sweep
Oil pressure switches can leak check under the rubber boot which covers the electrical connector.
Posted: Fri Aug 09, 2019 7:28 pm
by paultv
True story - mine was dribbling oil out of the rubber boot on the end of the switch.
Paul
Posted: Fri Aug 09, 2019 7:30 pm
by steve_k
paultv wrote: ↑Fri Aug 09, 2019 7:28 pm
Paul
mine did that till i replaced the switch & it's O ring, no more dribbles now.
Posted: Sat Aug 10, 2019 12:35 pm
by BenHar
Gavla wrote: ↑Fri Aug 09, 2019 3:17 pm
Ben
If the oil level gets too low the oil pump pick up cannot reach it so there is no oil pumped round so no oil pressure and the low pressure light comes on.
Ben
Posted: Sat Aug 10, 2019 1:30 pm
by martauto
Glad you got this one sorted mate,
