Fuse 28
Posted: Wed Aug 22, 2018 8:46 am
by gingerrusta
Hi guys
I’m having trouble with the 15amp fuse in socket location 28 in the fuse box.
The fuse blows and as soon as I go to replace it it blows straight away again .
Any ideas ?
Re: Fuse 28
Posted: Wed Aug 22, 2018 9:00 am
by Satan
Have you been fettling with the electrics?
Disconnect the cigarette lighter from the circuit as if something metallic falls in to it, it will cause a short circuit then try again.
Re: Fuse 28
Posted: Wed Aug 22, 2018 9:29 am
by arrisbmw
fuse 28 is supplying cig lighter, motor drive to Arial , and maybe fuel burning heater .
it should be 30 amps according to haynes
Re: Fuse 28
Posted: Wed Aug 22, 2018 10:12 am
by ChrisHC
As Brian Moore always says, a blowing fuse is not a problem, it is a symptom of a problem. You need to check the devices that are fused through there, and the wiring to them. The cigarette lighter sounds quite likely.
Re: Fuse 28
Posted: Wed Aug 22, 2018 10:34 am
by paultv
Lighter elements often fuse together causing a short or a shorted section making the current draw higher than the fuse can handle - also the the sockets tabs can get bent and short - quick test - remove the ash tray and pull the red/yellow cable spade off the lighter unit - problem gone?
Also, fuse 28 feeds the accessory connector - so pull out the red cable from position 2 on the accessory connector which feeds the aerial - if the problem goes away then the short is in the aerial lead to the boot or the aerial itself -
Paul :-)
Re: Fuse 28
Posted: Wed Aug 22, 2018 11:10 am
by gingerrusta
Cheers guys will try that
Re: Fuse 28
Posted: Wed Aug 22, 2018 1:01 pm
by Satan
But have you messed with the electrics in the last week or so? :mad:
Re: Fuse 28
Posted: Wed Aug 22, 2018 10:37 pm
by gingerrusta
Satan wrote:But have you messed with the electrics in the last week or so? :mad:
No nothing been messed with
Re: Fuse 28
Posted: Wed Aug 22, 2018 11:17 pm
by Satan
You wrote that with the fingers crossed on your left hand......... ;o))))
