Rear leak problem
Posted: Mon Jan 30, 2006 12:42 pm
well familiar story,
Ive the back seat out and ive had the panels out on each side. Right under the back seat, passenger side was wet, drivers side was alright. Both rear footwells are wet and its after making its way to the front footwell on the drivers side also so I'm assuming its made its way to the passenger side too.
Ive had the lining on the inside at the back out for a look at the rear archs and to be honest they dont look like theyre letting in a lot of water if any. They seem dry although the car has been sitting around for 10 days while the diff was being done. Where the arch meets the side of the car on the passenger side looks like a possible candidate although the drivers side looked ok.
Under the seat was wet and the footwells are wet, but the carpet that covers under the seat to the footwells was dry. Had a guy have a good look at the jacking points, bulkhead etc and says they're all good to go.
Poured water into the sunroof drainage channels and it lingers slightly but disappeared. Where the door card meets the window on the drivers side by where the seat belt emerges there was a small drip but nothing that could account for the amount of water thats after getting in. Boot floor is dry all over.
Theres a drainage channel on the rear quarter panel, passenger side, where is this for?
Any ideas from you guys? Suspension arrived last week and Im very reluctant to fit it untill I get this leak sorted.
Any help very very much appreciated with this one................
