Power steering belt replacement. Broken tensioner teeth.
Posted: Fri Jun 15, 2018 5:13 pm
Hi all
Power steering was making some horrible squeaking noises and not being sure when it was last done I decided to change the belt as per the wiki.
All went well until I needed to bring the new belt under tension, the toothed 19mm nut just spins.
I thought the nut had just worn over time but on closer inspection the teeth have snapped off the actual tensioner mechanism. The first couple have gone meaning I can’t tighten the belt.
I read elsewhere that you could manually push the steering pump with a pry bar but I’ve tried all angles and can’t seem to get it to move.
Can the asslembly be bought? Any other ideas? It’s been a day and am already fed up of no power steering.
Chris
Chris
