coolant
Posted: Mon May 14, 2018 4:30 pm
by j4gz
what coolant should i be using ? there was blue in mine first then mechanic used pink after he done timing belt water pump and cam seal which is the right one to use ?
Re: coolant
Posted: Mon May 14, 2018 7:06 pm
by brutus
,,, usally older cars use blue & i think cards from 1999 use pink,
it will say in the handbook, :)
Re: coolant
Posted: Mon May 14, 2018 8:24 pm
by DHFiS
Mine is blue and always has been
Re: coolant
Posted: Tue May 15, 2018 2:12 am
by biffer
From what i've read you can use pink stuff in our cars if you make sure you flush out all traces of old blue/green first.
it seems pink fluid only causes a problem in real olde-worlde cars with brass/copper radiators that are soldered.
