Lock set and ignition..
Posted: Thu Apr 20, 2017 6:56 pm
by marvelos
Hi zoners.. Just a quick question want to replace the locks and ignition on my 1987 tech 1 sport, would it be ok to replace with set from a face lift model.. Cheers
Re: Lock set and ignition..
Posted: Fri Apr 21, 2017 10:08 am
by ChrisHC
You know that with a lock rebuild kit you can rebuild the door locks to fit any key?
Posted: Fri Apr 21, 2017 4:44 pm
by marvelos
No I did not know that sir! Sounds like a much more sensible option.. Just get them on line?
Posted: Sun Apr 23, 2017 11:51 am
by ChrisHC
marvelos wrote:No I did not know that sir! Sounds like a much more sensible option.. Just get them on line?
Yes, they are a BMW item so Cotswold would be good. It is a little bit fiddly but satisfying when it works. Effectively it replaces the entire lock.
Posted: Sun Apr 23, 2017 3:19 pm
by Brianmoooore
The kit also includes the L shaped alloy piece on the back of the drivers door lock assembly, which is the part that suffers the most wear. Only available as part of the kit.
