Testing EWS
Posted: Fri Nov 04, 2016 4:08 pm
by prostreetpop
Hi all. Can you please tell me . . . . If I have voltage coming out the ews controller ( silver box with yellow socket ) on the thick green wire is my ews working correctly ?
Thanks.
Re: Testing EWS
Posted: Mon Nov 07, 2016 7:41 pm
by prostreetpop
I've got power out of the green on the ews and the moter turns over but I don't have a spark or power to the fuel pump.
Any ideas anyone ??
Cheers Mark.
Re: Testing EWS
Posted: Mon Nov 07, 2016 10:40 pm
by Brianmoooore
The signal output from the EWS unit is a binary coded digital signal (a series of pulses) which must match with what the ECU is expecting. The pulses will be integrated by a volt meter to give a voltage, but that won't tell you if the signal is correct.
Re: Testing EWS
Posted: Tue Nov 08, 2016 9:18 pm
by prostreetpop
Thanks for that.
Re: Testing EWS
Posted: Thu Nov 10, 2016 5:20 pm
by prostreetpop
When I put a multi meter on it I have different readings like 10.88v, 11.15v, etc. How can I find out if it's working or not. I feel it has a immobiliser fault as it turns over but I have no spark or fuel pump running.
Thanks.
Re: Testing EWS
Posted: Thu Nov 10, 2016 6:55 pm
by Brianmoooore
I'm not 100% sure, (anyone know for sure? DanThe?), but I don't think EWS recognition is necessary for the fuel pump to run, so you may be barking up totally the wrong tree.
Re: Testing EWS
Posted: Sat Nov 12, 2016 7:10 pm
by prostreetpop
It was a ews fault. Not sending the correct signal to the ecu. Now all up and running. Thanks for everyone's input
Just got to get the rear quarter painted and it put back together now.
Cheers. Mark.
