Brake bleeding sequence?
Posted: Thu Sep 29, 2016 6:34 pm
by e30-unit-soldier
Hi guys/girls
I've just finished fitting new brakes on my car aswell as braided hoses etc..
The brake hydraulic system is pretty much empty and as such I need to top up and bleed the system.
I need to know the sequence and any other advice/ information regarding this.
Thanks in advance!!
Re: Brake bleeding sequence?
Posted: Thu Sep 29, 2016 7:19 pm
by Brianmoooore
Lose the vacuum in the servo by pressing the pedal a few times, and start bleeding as far away from the master cylinder as possible, and work back.
On an E30, that means right rear, left rear, front right, then front left.
Pressure bleeder is preferable to risking relationship/marriage by asking the partner/wife/boyfriend to pump and hold the brake pedal.
Posted: Thu Sep 29, 2016 8:40 pm
by maxfield
Or gravity bleeding. Fill the master cylinder and let gravity push it through. Can take a while but the only option when you're on your own with limited tools. Gives you time to stick the kettle on.
Posted: Thu Sep 29, 2016 10:22 pm
by e30-unit-soldier
I bought one of them cheap "one man bleeding kit" basically a bottle with a tube in it with a ball bearing on the end...
Any good?
Posted: Thu Sep 29, 2016 10:42 pm
by bobbin1982
a jar with a piece of rubber hose to suit the bleed nipple...
Then part fill the jar so the hose is in the fluid.. easy as can be as when you release the peddle it just sucks up fluid instead of air
Posted: Thu Sep 29, 2016 10:43 pm
by bobbin1982
same method as above really.... piece of p$%s
