Inlet fanifold, injectors and rocker cover .
Posted: Tue Aug 23, 2016 5:08 pm
by trevski
Hi, I'm changing out the above items on Friday and would like to know what gaskets etc I will need to renew as well along the way. I have the rocker cover gasket but what else will be required please.
Re: Inlet fanifold, injectors and rocker cover .
Posted: Tue Aug 23, 2016 5:18 pm
by satan16v
Probably the inlet manifold gasket too
Might as well change the rocker cover breather pipe too. It's only about 15 quid and is usually blocked up with immulsified oil and crap. It runs from the rocker to the throttle body if memor serves correctly
Posted: Tue Aug 23, 2016 5:24 pm
by trevski
Thanks for that I'll pick them tomorrow
Posted: Tue Aug 23, 2016 11:51 pm
by aimlessrock
I would also look to overhaul the TB, couple of gaskets and a new rubber bung.
Posted: Tue Aug 23, 2016 11:52 pm
by aimlessrock
What engine btw?
Posted: Tue Aug 30, 2016 7:24 pm
by trevski
M20 b25
Posted: Sat Sep 03, 2016 8:49 am
by janc
Doing the same got two gaskets. And breather pipe but rubber bung? Didn't notice this on the parts diagram before ordering. Which rubber bung before i start? Thaks in advance. M20 B25. Just cleaning throttle body assembly and throttle position switch.
Posted: Sat Sep 03, 2016 11:49 pm
by BenHar
Posted: Sun Sep 04, 2016 7:14 am
by capri_rob
Change the rubber seals on the metal pipe that fits between the block and underside of the manifold. ( this can be a pig of a job, and getting the pipe in or out is NOT possible with the manifold in place.
On reassembly you need to compress the spring right down and use cable ties to keep the spring compressed, fit the manifold, then cut the cable ties and the pipe will pop back up into place.
Posted: Sun Sep 04, 2016 9:53 am
by janc
Thank you for the information. Haven't started yet. Where does item 26 fit? Guessing near TPS? Or on the throttle body? Trying to get straight. In my head first.
