Ignition switch Unknown white plug Grey and Grey/Brown Wire
Posted: Thu Jul 14, 2016 10:04 pm
by JoshH
Hi all
My ignition switch had died so I'm fitting a push start and ignition switch I had kicking about in the garage. The car is a track car anyway.
I have the majority of the wiring sussed but I'm slightly stumped by the small white connector with a grey and a grey/brown stripe wire.
I've done some searching about and can't find info on it, it's not mentioned on the wiring diagrams I have found so just wondering if I can leave it disconnected if it's something like the radio on signal for key pos 1?
Here is the little plug
Thanks in advance
Re: Ignition switch Unknown white plug Grey and Grey/Brown W
Posted: Thu Jul 14, 2016 10:21 pm
by Brianmoooore
Part of the parking light circuit, activated by the indicator switch.
Posted: Thu Jul 14, 2016 10:52 pm
by Buis
Indees. Mostly not on USA spec cars
Posted: Fri Jul 15, 2016 9:08 am
by JoshH
Ah ok thanks both. Non essential then even for mot.
I will reconnect anyway though. As it was inside the ignition switch wiring cover I assumed it was wired to the switch also
Posted: Fri Jul 15, 2016 9:26 am
by Brianmoooore
It is wired to part of the ignition switch. Closed in position '0', and open in positions '1','2' and '3'.
