temperature goes up and then fan start
Posted: Sat Jun 25, 2016 2:45 pm
by markus_74
Hello,
Does is it normal that extra fan start while car idle for 30 minutes and more and after the fan on for a while temperature goes down and then while temperature goes up fan start again it repeat again and again.
Or healthy car (visco, waterpump, etc) should not start the extra fan? I mean extra fan should not start because temperature always below the 92 degree.
Need advice please
Thank you
Markus
Re: temperature goes up and then fan start
Posted: Sat Jun 25, 2016 6:52 pm
by grants50
Yes everything working fine.
Posted: Sun Jun 26, 2016 4:30 am
by markus_74
I'm still worried because this is occurs after I change my waterpump skf with cheap no brand, should I replace again my waterpump with other skf brand?
Also I found some info at Web said like this.
The fan clutch:  Generally with a fan clutch problem you should notice overheating at idle and not so much during highway driving. This is because the main job of the fan clutch is to activate during idle in order to help cool the radiator while there is no airflow from driving.
IMPORTANT NOTE: never blame the auxiliary fan (electric fan). With a properly functioning system you should not even need the auxiliary fan.
Posted: Sun Jun 26, 2016 10:22 am
by MPOWERCRAZY
I would change the fan clutch
Posted: Sun Jun 26, 2016 10:31 am
by markus_74
Fan clutch is only about 10000 kilometers.
Posted: Sun Jun 26, 2016 2:44 pm
by pianist
If on idle the clutch fan is rubish at cooling your system because it is spining at slow speed that is why you have an auxiliary fan which does what it suposed to
Posted: Sun Jun 26, 2016 2:50 pm
by Brianmoooore
The way to check is to disconnect the auxiliary fan, and keep a close eye on the temperature gauge.
Posted: Sun Jun 26, 2016 4:47 pm
by markus_74
So it is not waterpump? But my clutch fan that.is weak?
Thank you I will check it
Posted: Sun Jun 26, 2016 8:33 pm
by Brianmoooore
Viscous clutch relies on hot air coming from the centre of the radiator to lock it up. Things like a partial blockage in the middle radiator cores, damage to the fins, and a missing/damaged fan shroud can all affect this.
