Alpina c2 2.7 interrupted-rough running
Posted: Mon Dec 28, 2015 9:09 pm
by sakkadas
Alpina C2 2.7.
Had this problem today, first time!
Car started and idled ok
When I tried to drive off I had interrupted - rough running from about 1000-1500 revs and that was it, removing my foot from pedal and idle is back to normal
I gave one more try but this time I put my foot right down , car roughed to about 2000 rpm and then cleared up, drove for about 20 miles with no problem
Once close to home I slowed down and I got back to max 2000 rpm even with foot full down and very rough running. When I got home FINALLY , I switched engine off and then back on and car run normal
Any ideas or thoughts please
Demetris
Cyprus
Re: Alpina c2 2.7 interrupted-rough running
Posted: Mon Dec 28, 2015 11:34 pm
by Brianmoooore
Check out the big convoluted air hose, between the AFM/air filter and the throttle body, for cracks and splits. A tear can open up under engine movement, causing an unmetered air leak, then close up when the throttle is lifted off again.
Posted: Tue Dec 29, 2015 2:42 am
by Kos
Brian Knows his stuff, Pacerpete and BSS325i as well may be able to help
Demitri, if you get stuck give Chris a call at CC racing in Lemesos
http://www.ccracingcy.com/contact.php
Posted: Tue Dec 29, 2015 7:13 pm
by sakkadas
Have checked for air leaks , all looks ok, I have been driving the car all day long today and I had no problem at all with it, thanks for the help anyway Brian and Kos!!!!!
Posted: Mon Jan 04, 2016 7:38 pm
by sakkadas
Car is still fine but I Will order a fuel pump to have on my spares shelf as it's going to be needed at some point I would guess!!!
