M30 Missfire
Posted: Tue Oct 27, 2015 12:03 pm
by Fal_325i
I have acquired a 3.5 M30 powered e30 which is misfiring, any ideas what it could be?, what are the best and worst case scenario's?
Re: M30 Missfire
Posted: Tue Oct 27, 2015 12:14 pm
by jimbom30cab
Is this a blue carbio ?
I'd check for
Spark
Fuel
and
Compression
in all cylinders.
Re: M30 Missfire
Posted: Thu Nov 05, 2015 2:46 pm
by zaust
check the dizzy cap very carfully too. they tend to crack in odd place's causing arcing.
Re: M30 Missfire
Posted: Thu Nov 05, 2015 3:01 pm
by 87mtech27
Thought you was dead against the anchor Fal?
Re: M30 Missfire
Posted: Thu Nov 05, 2015 6:38 pm
by Brianmoooore
First thing is to determine whether it's a particular cylinder (or cylinders) that isn't firing, or a random misfire. Ideally, you should short each plug lead to earth in turn, but pulling the cap off doesn't usually cause harm.
Re: M30 Missfire
Posted: Thu Nov 05, 2015 7:27 pm
by jimbom30cab
Happened to me and I would NEVER advise anyone to do that
Re: M30 Missfire
Posted: Thu Nov 05, 2015 9:58 pm
by Brianmoooore
If you're daft enough to do it with your fingers, then you deserve what you get!
Re: M30 Missfire
Posted: Thu Nov 05, 2015 11:51 pm
by fixedwheelnut
Buy a pair of proper plastic pliers made for the job
Re: M30 Missfire
Posted: Fri Nov 06, 2015 1:05 am
by Rav335uk
Brianmoooore wrote:If you're daft enough to do it with your fingers, then you deserve what you get!
HAHAHAHAHA
