Convertible leak
Posted: Wed Jun 03, 2015 4:53 pm
by Sach_UK
hi i have managed to source a roof in better condition than my original roof. i have fitted it using only one shim as i believe the alignment has improved, however at the very front of the roof by the windshield seal still leaks near the OBC. any ideas, have also sealed it with a line of black silicone sealant.
Re: Convertible leak
Posted: Wed Jun 03, 2015 5:44 pm
by Gavla
I used a rubber seal from seals direct across the top front window section...job done...
Posted: Wed Jun 03, 2015 5:54 pm
by daimlerman
Lubricating the rubber seal with something like Vasaline will soften the rubber and often cure a small leak.
Posted: Thu Jun 04, 2015 1:26 am
by Sach_UK
Thanks Gavla and daimlerman,
Gavla - which seal did you go with as there are many to choose from?
Posted: Thu Jun 04, 2015 4:15 pm
by Gavla
don't recall...but it is flat foam with a little "lip" on one side...
