best front brake pads
Posted: Sun Apr 05, 2015 7:17 pm
by pimpmobil
I have a 1987 325i. What are the best front brake pad?
Any help would be great.
Re: best front brake pads
Posted: Sun Apr 05, 2015 7:24 pm
by Silverfang
It entirely depends on what you mean as "Best brake pad" for... what?
Track day?
General day to day?
Fast road?
Posted: Sun Apr 05, 2015 8:19 pm
by pimpmobil
general day to day
Posted: Sun Apr 05, 2015 9:48 pm
by polsta
Just put pagid on mine pimp, decent price and decent pads for day to day use
Re:
Posted: Sun Apr 05, 2015 9:55 pm
by pimpmobil
many thanks
Posted: Sun Apr 05, 2015 10:14 pm
by polsta
Get em from euros for cheap , don't firget to order the brake sensor wire too
Re:
Posted: Mon Apr 06, 2015 1:16 am
by reggid
textar or jurid are the OEM brands for pads
Re:
Posted: Mon Apr 06, 2015 10:24 am
by Brianmoooore
reggid wrote:textar or jurid are the OEM brands for pads
So are Pagid.
Re:
Posted: Mon Apr 06, 2015 1:36 pm
by capri_rob
You can currently get ATE or Pagid for less than £22 from carparts4less both absolutely fine for standard road use.
If you have other stuff you might need shortly if you spend over £50 there is a £5 off discount code
Re:
Posted: Mon Apr 06, 2015 2:04 pm
by Brianmoooore
Check the thickness of your discs before you order. I've come across an alarming percentage of E30s (and other BMW models) that have discs worn alarmingly below the minimum, and are full of cracks. As a rough rule of thumb, if the discs weren't changed the last time the pads were renewed, they will need changing this time.
Pagid also make discs, which are fine for a road car.
Posted: Mon Apr 06, 2015 4:25 pm
by polsta
Pagid discs are only 21 each from CP4L, so with pads is about 120 odd , work out re best way to order/separate orders using the codes whst works for best discount , and get a nice discount
Only driven 2 miles with my new pagid discs and pads so can't comment much but they feel good, and of course a far greater improvement over the old ones that needed replacing
