M40b18 1993 Touring running rich - at a loss!
Posted: Mon Mar 02, 2015 6:55 pm
I have searched around and have had this problem a while and wondered if anyone could shed any light on the situation. I have replaced everything suggested
I do a 35 mile trip to work mainly motorway (gets a good chanced to warm up) sitting at 65-70 and get on a bad fill up 23mpg and on a really good fill up 28mpg - the exhaust smells rich and sometimes i have a dodgy idle (flicks between around 600 and 1100rpm but not all the time! - most of the time idle is good)
I have replaced the blue temp sensor and checked it at the ecu - getting 250ohms when hot, the o2 sensor has been replaced and reporting properly (car has no cat).
The temp gauge was sitting at a quarter before i changed the stat and now sits at half way (this hasn't effected the mpg in any way)
I have a spare engine so can nick bits off it, so far I have done a tank on another AFM (no difference), can't see any air leaks (sprayed easy start on all the hoses with no change to idle)
I am at a loss as to what would cause bad mpg, car has done 123k miles.. has anyone any other suggestions i can try?
