What size Torx?
Posted: Wed Jul 30, 2014 2:47 pm
by Falamon
To remove the cam sprocket so I can replace the camshaft seal and O-Ring behind it, unfortunately haven't got one big enough :(
Re: What size Torx?
Posted: Wed Jul 30, 2014 3:40 pm
by Falamon
Found it - T50 Torx
EDIT - this is quite wrong...
Re: What size Torx?
Posted: Wed Jul 30, 2014 4:27 pm
by daimlerman
Humm,mine is an E14!
Re: What size Torx?
Posted: Wed Jul 30, 2014 4:31 pm
by Falamon
Interesting... thanks daimlerman. I read a few threads to find it and they said T-50! I'll get a big set of torx bits later tonight :)
Re: What size Torx?
Posted: Wed Jul 30, 2014 5:01 pm
by daimlerman
It's a male torx bolt,these are all E bla bla.
Female torx fixings,such as plastic bumper mounts,are T bla bla,and look a little like an allan key.
Re: What size Torx?
Posted: Thu Jul 31, 2014 12:46 pm
by HairyScreech
Yep, Often referred to as an Etorx.
I believe there has been both male and female bolts in that position over the years, I think I have seen both a slightly dome headed Torx and a collared Etorx.
I think the change may be related to the location of the distributor as early carb engines use a normal distributor under the inlet manifold.
