Zone Chip - Kudos to Ant
Posted: Thu Jan 05, 2006 5:45 pm
by Razza
Sorry if this is in the wrong place but I just fitted my zone chip today and am astonished by the difference, no more flat spots, much more responsive / better throttle control and feels nippier all round....wish I'd done this ages ago....
For anyone hesitating - get one asap, it's like driving a new car, Ant - we are not worthy :bow:
Posted: Thu Jan 05, 2006 5:53 pm
by beavis2k4
seconded!!
:bow:
Re: Zone Chip - Kudos to Ant
Posted: Thu Jan 05, 2006 5:58 pm
by JoeP
Razza wrote:Sorry if this is in the wrong place but I just fitted my zone chip today and am astonished by the difference, no more flat spots, much more responsive / better throttle control and feels nippier all round....wish I'd done this ages ago....
What engine and chip combo have you got. I had one on my Christmas list, along with most of the shop but my family thought my car was plenty fast enough already!
Posted: Thu Jan 05, 2006 6:02 pm
by Steviec
Cant wait till the postie delivers mine :D
Posted: Thu Jan 05, 2006 10:33 pm
by r_9ore
take it these are the chips in the zone shop?
Posted: Thu Jan 05, 2006 10:37 pm
by JazzMan
r_9ore wrote:take it these are the chips in the zone shop?
Yes they are, or contact Ant directly :D
Posted: Thu Jan 05, 2006 11:05 pm
by Razza
I've got a 325i SE and went for the "wild" chip, I've not done any real motorway driving to test it to the max yet but went for a spin after fitting it and couldn't believe the difference.
My car used to "chug" at idle threatening to cut out and I could depress the throttle about an inch before getting any bite as well as having a variety of flat spots between gear changes. Think this is a general age issue as my old 318i used to do all of these and every mechanic I went to couldn't rectify it.
Order one up and follow the fitting instructions in the articles section to the letter and you'll notice a big difference. Took me about 45 mins all in, started her up and she coughed and spluttered for about 5 minutes and I thought "oh fzuk, what have I done", then the shaky idle stopped and picked up and she started running smoother than I've ever known it since I've had her. Took her for a spin and it felt like another car - best Ԛ£55 I've spent for a long time.
Going to give her a sterner test tomorrow :twisted:
Posted: Thu Jan 05, 2006 11:31 pm
by kam-325i
What is the difference between the flavours ?
Mild or Wild ?
Posted: Thu Jan 05, 2006 11:48 pm
by Wid77
Can anyone tell me if this zone chip alters the economy of the car much? I have a 1988 325i. Also, how do you contact Ant directly, i.e. who is he?
Cheers.
Posted: Fri Jan 06, 2006 12:44 am
by oguz327
should get mine through any day now, i take it its normal for motor to run like a bag of shit for a while when first starting up?
Posted: Fri Jan 06, 2006 1:23 am
by aus325
I'll add mine name to the chorus of praise for Ant's zonechips.
Top drivability upgrade.
Top bloke.
Wid77 - economy appears unchanged. More of a response/drivability upgrade than a power upgrade..
Posted: Fri Jan 06, 2006 4:12 pm
by gcorky
another thumbs up ,i also think ecomony slightly better around 27 round town now .
Posted: Fri Jan 06, 2006 7:19 pm
by charlE30
gcorky wrote:another thumbs up ,i also think ecomony slightly better around 27 round town now .
27 :clin: I better get one, I'm lucky to get 22 round town driving like an old man (and I'm 30)
On a serious note I think I will get one with the way a lot of people (not just on this thread) have been going on about them. It'll be interesting to see the difference as I aready have a Superchip and one marked Alpina??
kam-325i wrote:What is the difference between the flavours ?
Mild or Wild ?.
And what is the difference before I buy??
Posted: Fri Jan 06, 2006 10:13 pm
by Wid77
I wouldn't mind knowing the difference between mild & wild too.
Posted: Fri Jan 06, 2006 10:39 pm
by hammoj28
I am really jealous. Please, please, please, please make a zone chip for the 318is? :(
Posted: Fri Jan 06, 2006 11:38 pm
by Brianmoooore
oguz3001 wrote:should get mine through any day now, i take it its normal for motor to run like a bag of shit for a while when first starting up?
E30 ECU will run rough for several miles after battery disconnection for a while, until it learns new idle settings.
Shouldn't run rough while warming up normally.
If it does, check the blue water temp sensor.
Posted: Fri Jan 06, 2006 11:40 pm
by Brianmoooore
Wid77 wrote: Also, how do you contact Ant directly, i.e. who is he?
Cheers.
One of the mods on this site.
Posted: Sat Jan 07, 2006 12:05 am
by oguz327
do i need to disconect the batery before i remove old chip brian?
Posted: Sat Jan 07, 2006 12:52 am
by aus325
oguz3001 wrote:do i need to disconect the batery before i remove old chip brian?
YES !!
Posted: Sat Jan 07, 2006 10:14 am
by Brianmoooore
YES !!
No, since presumably you'll unplug the big ECU connector and have the ECU on the bench.
Most of you will probably think I'm mad, but with all the electrical work I do on E30s, I rarely dissconnect the battery. (Puts the radio out of action).
Posted: Sat Jan 07, 2006 10:50 am
by gcorky
my car was actually cutting out when first fitted on the a19 in traffic,car wouldnt rev properly,eventually started and once settled has been spot on.
run for 10 mins idling then take for a run but i got stuck in traffic that isnt good for learning ecu again!!!!!!stop start open closed throttle etc!!!!
i didnt disconnect ecu for the reasons brian has said.
one note my ecu was a later one and so had a row of small screws on the case that had to be removed befroe opening up.this isnt the case on the tech guide.
Posted: Sun Jan 08, 2006 2:19 pm
by Incitatus
I've got a wild chip on my 325, and it really is very good. But I thought the limiter is set at 7k on the wild chip, and I'm curious why this is ok to do. Does anyone know?
Posted: Sun Jan 08, 2006 8:01 pm
by DazzyA
Just fitted new head gasket after hitting 7k with a new chip. I did find that one of the head bolts was missing though. I made the mistake of taking the mild zone chip out and replacing with another brand of race chip and the zone chip was first rate.
You live and learn.
Posted: Sun Jan 08, 2006 9:40 pm
by Jon_Bmw
DazzyA wrote:Just fitted new head gasket after hitting 7k with a new chip. I did find that one of the head bolts was missing though. I made the mistake of taking the mild zone chip out and replacing with another brand of race chip and the zone chip was first rate.
You live and learn.
A head bolt was missing, now that's an achievement :eek:
Posted: Sun Jan 08, 2006 9:59 pm
by M3Tony
Any answer yet to questions re difference between "Mild" and "Wild".....i can only find 1 chip for sale for 1990 325i Sport .... are there different chips for sale ?
Posted: Sun Jan 08, 2006 10:13 pm
by DazzyA
You live and learn.
Yeah, previous owner said friend in garage had fitted new head in August. The head is new and the bolts are, can't figure it out.
Mild chip is very refined, drivability is excellent, really smooth, tick over is great. Acceleration not brilliant, but loads of torque. Can't comment on the wild yet. Sorry. If you order just put a note in that you want a wild or you will get a mild.
Go for the wild otherwise you will get the mild then after a few days think, shit I want a wild one. Trust me I know.
Posted: Mon Jan 09, 2006 10:21 pm
by Wid77
Anyone fancy this on ebay? Not sure if mild :| or wild :evil: though and doesn't say how old it is but only Ԛ£30 + Ԛ£2 p&p at the moment:-
http://cgi.ebay.co.uk/Tuning-Chip-for-B ... dZViewItem
Hope this link works. If not then it is item number 8028625852.
Posted: Tue Jan 10, 2006 9:21 am
by Steviec
Id spend the extra money and just get one from the shop, atleast you know those ones are good with the amount of people using them on here.
Postman still hasnt delivered mine though :cry:
