Scuttle rust issues
Posted: Sun Jul 06, 2014 9:44 pm
by Flute
Hi, just had a small hole appear in the corner of my scuttle right in the corner by the passenger side. What are my options to fix please? No other rust appears on the rest of the panel, just a hole an inch round :(
Flute.
Re: Scuttle rust issues
Posted: Sun Jul 06, 2014 10:09 pm
by Brianmoooore
It's where a large blob of sealant behind the panel has shrunk and detached itself, leaving bare metal exposed, which rusts through in time.
Chop out all the rusted area (which probably isn't much over about 40mm in diameter) and MIG weld a plate in, followed by a skim of filler and paint. Paint the reverse side as well, through the hole where the grill in the scuttle fits.
Posted: Mon Jul 07, 2014 11:00 pm
by Flute
Thankyou very much for your reply. Your absolutely spot on with your explanation. It's right in the corner and behind it there is a mastic type sealant. It's easy to chop out and get a plate welded in. Job for winter along with rear arches, lower doors and a new d/s front wing. Then it's bodywork compete and on to the new roof that's needed.
Flute.
Posted: Mon Jul 07, 2014 11:01 pm
by Flute
Forgot to mention, Brian this is exactly why I joined this forum. Good quality information and sensitive to the owner and car. Thankyou
Flute.
