Fuel/Brake Pipe bracket bush
Posted: Thu Jun 12, 2014 12:31 pm
by Idol
When removing my fuel and brake line from the car the screws holding the brackets have sheered. Item 6 is the bush in this link
http://www.realoem.com/bmw/showparts.do ... g=16&fg=15
How are they connected to the chassis? Is it just a hole drilled and the bush is popped in from the inside?
I believe they are NLA. What have people done about replacement/fixing said problem?
Re: Fuel/Brake Pipe bracket bush
Posted: Thu Jun 12, 2014 3:18 pm
by bdx
Had same problem,
Grind or cut broken stud flush with boss.
Drill and tap M3 or M4.
Fiddly.
Posted: Thu Jun 12, 2014 3:49 pm
by Idol
Nice one. Thanks
Posted: Tue Jun 10, 2025 4:22 am
by hb02
Hi there , Ive run in to the same problem and ive only just realised the problem i have after getting it back from being sprayed/under sealed. When you say drill and tap a m3 or m4. Where exactly does it drill in to? Last thing i want it to go through the floor. If you can please clarify on exactly what i have to do it would be greatly appreciated. Thanks
Posted: Tue Jun 10, 2025 5:01 pm
by martauto
Good luck with the reply, not been on here for nine years !!
