harmonic damper battery in the boot
Posted: Sat Jun 07, 2014 12:17 pm
by aimlessrock
Have any zoners (who have cabbys) removed the weight in boot and done the battery in the boot conversion?”¦has it made any difference?
any comments would be most welcome.
cheers
Gary
Re: harmonic damper battery in the boot
Posted: Sat Jun 07, 2014 12:26 pm
by ImysE30
I've done and not really noticed a difference. I wouldn't removed it altogether.
Posted: Sat Jun 07, 2014 4:57 pm
by aimlessrock
thanks Imy, so relocating the battery and the removal of the harmonic damper in its place has had not left you with any additional vibration issues etc??
assuming you had no issues and the weight of the battery substitutes for the harmonic damper then it could be removed and the battery located in its place??
hmmm”¦anyone else done this?
Posted: Sat Jun 07, 2014 6:29 pm
by Brianmoooore
Whether or not you can notice the removal of the damper depends on the condition of the rest of the suspension and car. If the suspension is as new, then you'll notice it. 20 year old suspension and you won't.
The damper isn't a rigidly mounted dead weight - it sits in rubber mounts which are essential to its operation, so substituting a battery for it, even one of the same weight, isn't going to have the desired effect.
Posted: Sat Jun 07, 2014 6:40 pm
by aimlessrock
Thanks Brian, the whole suspension is basically new (sub 6 months old)..i accept your comments and will leave it..
cheers
Posted: Sat Jun 07, 2014 8:46 pm
by ImysE30
You could remove the rubber mounts and stick them underneath the battery :idea: :?:
Posted: Sun Jun 08, 2014 8:53 am
by aimlessrock
ImysE30 wrote:You could remove the rubber mounts and stick them underneath the battery :idea: :?:
That had crossed my mind, but I'm not sure I like the idea
of the battery wobbling around in the boot..!
Posted: Sun Jun 08, 2014 8:54 pm
by ImysE30
You would secure it down though using the mounts or make some up? :)
Posted: Mon Jun 09, 2014 3:40 pm
by BMW_E30vert
Did the m3 convertible not have a battery in the boot? im planning on doing this and was looking on realoem for the parts fitted on a m3 cab
http://www.realoem.com/bmw/showparts.do ... g=61&fg=30
Posted: Mon Jun 09, 2014 4:53 pm
by pacerpete
The E30 M3 convertible has the same 'weight' in the boot and a unique metal battery tray is attached to it.
E36 convertibles were actually specified with a special vibration proof battery so that the battery effectively became the harmonic damper.
Posted: Mon Jun 09, 2014 10:13 pm
by aimlessrock
Your a mind of info Pete, do you think an e36 battery could work for
an e30....?..what about E46 cab... Did they have such a set up?...hmmmm
Posted: Tue Jun 10, 2014 2:35 am
by e30rapidic
I removed the weight out of mine.The only difference was a 3mm increase in ride height on the RR that I adjusted out. I have bilstein sports, eibach pro kit up front, coil overs in the rear, larger sways, new bushings, strut bar, etc...
