Coolant flush....
Posted: Mon May 19, 2014 1:33 pm
Hi,
I started to strip down the cooling system on my 318is
i flushed trough the rad (backwards as well as forwards) and the water was a transparent grey film but is now clear. I took a look in the water pipes and there is a grey film...... Any idea what could be causing this and should I flush the hoses and block etc? Have read wiki just wondered if there was anything else I could do......
Water pump and thermostat are being changed as have no history of any change....
