Do I keep the ABS?
Posted: Tue Apr 22, 2014 10:00 am
by harvey_inc
Hi Guys
New to BMWs and fitting a M52 to my e30 touring, Ive got the smaller brake servo from a clio.....do I need the abs?? do most people get rid of it for that clean bay look and will it affect the MOT
Suggestions please
Alan
Re: Do I keep the ABS?
Posted: Tue Apr 22, 2014 10:05 am
by daimlerman
There's no reason to remove the ABS,just a minor re-shaping of the pipes to the master cylinder is required.
Posted: Tue Apr 22, 2014 10:12 am
by gooseygander110
depends what you are using it for ........If for the road as a daily, I would keep it. If for the track I would leave it out or make it switchable !! 8)
Posted: Tue Apr 22, 2014 10:21 am
by jmc330i
Definitely more work to remove it compared to reshaping or remaking the pipes to the master cylinder.
It's been mentioned on here before, that if it's going to be MOTd you will need to remove every trace of the system for a pass.
Posted: Mon Apr 28, 2014 7:41 pm
by harvey_inc
thanks for the replys
so looks like its more trouble than its worth, going to be remaking all the lines in the future so could possible tidy it a bit that way
