Fuel leak 318is
Posted: Sat Feb 15, 2014 11:26 am
by A18RPF
This is an issue that reared its head when my e30 was last on the road, and with a trip to the Nurburgring coming up it needs sorting.
In short the fuel tank only fills halfway before it starts to pour out all over the floor. If you only fill it to half a tank it's fine, but there's obviously a leak. The problem is I don't know if my car (318is) has the smaller or larger tank? As I understand the larger tank is 'bridged' above the prop. The car is up on stands and has a fuel line connecting the two halves of the tank, could this be the culprit?
Just don't want to take the prop off and drop the tank to find there's nothing wrong with it
Re: Fuel leak 318is
Posted: Sat Feb 15, 2014 11:53 am
by daimlerman
As your car is up on stands,the 'fuel tank test' is easy to do.
Get hold of the inlet stub,just forward of the o/s rear wheel,and give it a good yank.ANY movement indicates that the welded in stub pipe has rust damage.
Repairs are not really advisable,but replacement pattern tanks are available.
Re: Fuel leak 318is
Posted: Sat Feb 15, 2014 2:36 pm
by Brianmoooore
All tanks are 'bridged' above the prop., but only the 55 litre (smaller) tank has a pipe joining the two halves under the prop.
Re: Fuel leak 318is
Posted: Sat Feb 15, 2014 3:18 pm
by A18RPF
So it's still highly likely that the bridging piece above the prop is where the leak is?
Re: Fuel leak 318is
Posted: Sat Feb 15, 2014 6:36 pm
by Brianmoooore
A18RPF wrote:So it's still highly likely that the bridging piece above the prop is where the leak is?
Won't be there. Most common is where the fuel goes nto the tank from the filler, followed by a split O ring for the fuel pump, followed by rust eating through the seam where the top of the tank is welded to the bottom.
Re: Fuel leak 318is
Posted: Tue Feb 18, 2014 9:16 am
by rix313
I had the O-ring go around the fuel pump and that leaked like crazy. Dealers supply new ones for next to nothing.
Re: Fuel leak 318is
Posted: Tue Feb 18, 2014 1:25 pm
by A18RPF
I've had the pump out and the o ring was fine. It doesn't leak at all unless the tank is over half full
Re: Fuel leak 318is
Posted: Tue Feb 18, 2014 1:29 pm
by Brianmoooore
Brianmoooore wrote: Most common is where the fuel goes nto the tank from the filler.
Re: Fuel leak 318is
Posted: Tue Feb 18, 2014 6:31 pm
by FZB
BMW will supply a new fuel tank for about £640, it's the fitting and anything else hidden that needs replacing when you remove it that things start to add up.
Re: Fuel leak 318is
Posted: Tue Feb 18, 2014 9:48 pm
by Brianmoooore
There are pattern tanks available, and plenty of good second hand OE ones around, so no need to swell BMW's coffers for this.
I wouldn't dream of replacing the tank without replacing the brake pipes above and behind it.
Re: Fuel leak 318is
Posted: Wed Feb 19, 2014 2:08 pm
by FZB
Very true.
