325i wont start, hazards on permanately
Posted: Tue Dec 31, 2013 11:11 am
by Tomux
Hi
Came to start car one morning all dash lights came on but no crank. First tought battery gone flat. Replaced with new battery. Once connected new battery hazard lights started double flash permanately even with egnition off. Car won't start, no crank.
Please help!!!
Re: 325i wont start, hazards on permanately
Posted: Tue Dec 31, 2013 11:33 am
by broadie
Have you got an alarm fitted?
Posted: Tue Dec 31, 2013 11:58 am
by Tomux
I bought car 2 months ago it looks like it had or still have some sort of alarm because there is siren under bonnet but I never used it. In ash tray I found one button fob with BMW letters on.
Posted: Tue Dec 31, 2013 12:36 pm
by broadie
Can you key the alarm on and off again.
Have you tried disconnecting the battery for 30min then reconnect.
Posted: Tue Dec 31, 2013 12:48 pm
by Tomux
Fob never (since I own the car) had batteries in. I tried to disconnect battery but when battery connected again about 30 sec later hazards comes back on again.
Posted: Tue Dec 31, 2013 1:25 pm
by Speedtouch
Suggest you try putting some new batteries in the fob.
Alternatively, disconnect the appropriate fuse (if fitted) to the alarm, and reconnect the link that the immobiliser circuit has been spliced into, which will either be to the igntion coil or the green wire that goes under the dashboard, usually visible if you remove the glovebox.
Posted: Tue Dec 31, 2013 4:56 pm
by Tomux
Posted: Tue Dec 31, 2013 5:11 pm
by Speedtouch
Good to hear that, dude.
