Oil ways...
Posted: Tue Dec 27, 2005 11:59 am
See on the 325, next to the head bolts, there are small holes, i take it these are oil ways?
a few of my head bolt washers are covering these holes, could this be affecting the oils travel into the head causing my rattle? (see post "rattle after rebuild") the haynes manual doesnt say anything about these washers needing to be clear of the holes...
i have removed and cleaned the spray bar, 1 hole was blocked, there is now oil coming from it. i ran it without the rocker cover off the engine to get a better look. everything seems fine, the rattle then comes and goes randomly. i poured new oil over everything as its running and it doesnt affect the noise!
i then got a high pitch screech/squeal (like compressed air squeal (letting air out of a baloon slowly by pinching the end type noise)! could this be the washers covering the holes? dunno how it would make a rattle tho!?!!??
If the cam journals were fucked would this cause a rattle?
any answers to any of my questions would be great...
