ABS Light??
Posted: Tue Dec 20, 2005 7:03 pm
by bullitt
Hi Folks..
My 87 sport has been in storage for 18mths, i fired it up at the weekend and the ABS light is lit?
Any ideas..
Car is driving 100%..
Thanks...
Posted: Tue Dec 20, 2005 8:37 pm
by kam-325i
Is the light staying on from turning the ignition on or is it coming back on after you have pulled off/gone above 10Mph ?
Posted: Fri Dec 23, 2005 5:16 pm
by bullitt
The ABS light stays on even when driving??
Posted: Fri Dec 23, 2005 10:45 pm
by A1BMW325iSport
most likely dirt/corrosion on the pickups give the sensors and pickups a clean
Posted: Sat Dec 24, 2005 12:26 pm
by Jon_Bmw
Bullit if you explain how the abs light is coming on it would help us help you.
Right...
Does the light come on when you have the ignition on?
Does the light go out when you start the car or does it stay on?
If the light went out when you started the car does it go on when you reach a particular speed(5mph probably)?
The more info you give the more chance we have of helping
Posted: Thu Dec 29, 2005 5:08 pm
by bullitt
Jon_Bmw wrote:Bullit if you explain how the abs light is coming on it would help us help you.
Right...
Q1 Yes..
Q2 Light stays on..
I will check the sensors and clean the pickups..
Thanks Folks..
