How can I tell if I have an lsd?
Posted: Mon Dec 19, 2005 10:01 pm
by johnna
By using my etk. Enter Vin No, then I?????
Posted: Mon Dec 19, 2005 10:06 pm
by DazzyA
just read a post by Simon, sy's jack car up at rear and turn a wheel, if other turns same way- lsd. if opposite way- open diff.
Posted: Mon Dec 19, 2005 10:20 pm
by smithy318i
floor it out of a corner and see how many tyre tracks you make winkeye
Posted: Mon Dec 19, 2005 10:23 pm
by DazzyA
should be two yeah??
Posted: Mon Dec 19, 2005 11:30 pm
by johnono
with a slipper 2 yes, but can also be done with an open.
good if u can jack the back up and out of gear, turn a wheel by hand. if the opposite rotates opposite u have an open diff.
if its a bastard to turn its a lsd or u need to change your oil :lol:
Posted: Tue Dec 20, 2005 1:24 am
by astondg
johnono wrote:with a slipper 2 yes, but can also be done with an open.
Or you left the handbrake on :D .
Yes like johnono said it is possible in certain situations to spin both wheels even with an open diff. If you do it that way try putting one wheel off the road on the dirt and one on the bitumen then check to see if both spin. In that situation an open would probably only spin the one on the dirt. You can also just lift up one side at the back and try to turn that wheel (handbrake off and out of gear) and if it turns easy it is open, if it is hard to turn then it might be an LSD but probably not working as well as it could, and if you can't turn it at all (or without using a LOT of strength) then it is probably an LSD. I can't turn 1 wheel at all with my LSD.
But the best way is like people have said, lift the whole back up and turn one wheel, LSD would mean the other will turn the same way.
Aston
Posted: Tue Dec 20, 2005 2:58 am
by stevetigger
My sport had lsd, and when I had it on ramps the wheels turned in opposite ways!
Posted: Tue Dec 20, 2005 3:00 am
by stevetigger
Aston
Same with you, proven lsd turn in the opposite way!
Posted: Tue Dec 20, 2005 5:02 am
by astondg
stevetigger wrote:Same with you, proven lsd turn in the opposite way!
Really? I have heard people say that before (that an LSD can turn opposite ways in that test) but it has never happened to me. Seems strange that the same type of diffs would act differently, unless you have a non-standard LSD? I presume you are sure it is an LSD and it is in good working order?
I guess then the best way is really to open it up and have a look, or try the first test I said. That test is actually recommended in some manufacturers owners manuals, put one wheel on the dirt and one on the bitumen/tarmac and try to spin them.
Aston
Posted: Tue Dec 20, 2005 8:10 am
by hoshy
perhaps Steve's isn't locking up?
Posted: Tue Dec 20, 2005 8:35 am
by Simon
An LSD should turn both wheels the same way, open diffs will turn the wheels in opposite directions.
Posted: Tue Dec 20, 2005 7:20 pm
by keith52
I believe both drives turn in the same direction (LSD)
Posted: Fri Dec 23, 2005 10:38 pm
by johnna
Cheers for the replies guys, but....
How can I tell using ETK???
Jacking the car up is a major pain because it is so low.
Also whilst a healthy slipper will turn both wheels, what if the wrong (cheaper) oil has been used in an LSD? Well silly things happen. I've seen it too often in Capris to trust that test alone.
I have been told about a tab attached to LSD difs, but I must admit I was very, very drunk...
LSD
Posted: Sat Dec 24, 2005 3:36 pm
by darkslider
The curtains will become alive and Mars bars will chase you down the street.
Posted: Sun Dec 25, 2005 1:20 am
by johnna
Why is that painting winking at just me?
Not done that since the early 90's and ended up causing a mini riot by all accounts. Threw a German student in the river for the apparent crime of 'pretending to be German'. I was not convinced you see....
Posted: Tue Dec 27, 2005 7:18 pm
by Globulator
Just to add my 0.03 euros...
I confirmed the existence of my LSD when I jacked up one wheel in 5th to turn the engine for valve clearances.
If you get a mate to hold up the back you should get a trolley jack under the diff. Then get him/her/them to hold one wheel while you try to spin the other one. You should find it very difficult (1 person power vs 25% of 175BHP).
If it's almost like a solid (no diff) axle fine (as that is what is does). If it's easy or (worse, oh so much worse) and the back wheels freely move in opposite directions then there is no limited slip and you'd better be careful playing in the snow :)
Torsen diffs might be different (but that aint an LSD).
