Windows not working with door open
Posted: Mon Oct 14, 2013 2:15 pm
by JungleGus
For some reason, I always have this STOP working on any e30 I get...the windows stop working with the door open (the window switches aren't illuminated either).
I don't THINK it's a door shut sensor thing - is there a fuse that blows? If so - which one?
I think I am being really dumb...
Thanks!
Gus
Re: Windows not working with door open
Posted: Mon Oct 14, 2013 2:17 pm
by Brianmoooore
Fuse is 28. Shared with the lighter and electric aerial.
Posted: Mon Oct 14, 2013 2:18 pm
by TPS
Common Problem that
Posted: Mon Oct 14, 2013 3:49 pm
by JungleGus
The aerial and cigarette lighter seem OK - will check it out. Thanks!
Posted: Tue Oct 15, 2013 2:48 pm
by bdx
Check door pin switch. It's has double contacts.
Posted: Tue Oct 15, 2013 8:59 pm
by gnrsoul
bdx wrote:Check door pin switch. It's has double contacts.
I had same problem and was this, the door pin switch was corroded cleaned it up then all was good
Posted: Mon Nov 11, 2013 5:17 pm
by JungleGus
Dirty door pin switches - cleaned and fixed!
