rev counter not working
Posted: Mon Jul 08, 2013 11:03 am
by frenchi
rev gauge not working any idears
Re: rev counter not working
Posted: Mon Jul 08, 2013 11:13 am
by Brianmoooore
Prime suspect is the SI board batteries.
Posted: Mon Jul 08, 2013 11:46 am
by frenchi
you are allways there mate ,what and where are they
Posted: Mon Jul 08, 2013 11:50 am
by Grrrmachine
Posted: Mon Jul 08, 2013 3:40 pm
by frenchi
ok changed battery board over from one that was ok,reving and working ,pluged into mine and nothing only when you switch off it flickers.help brian
Posted: Mon Jul 08, 2013 4:45 pm
by Grrrmachine
And did you read the "Rev Counter Not Working" page?
Posted: Mon Jul 08, 2013 4:59 pm
by frenchi
yep went through that but it did not help.
Posted: Mon Jul 08, 2013 5:05 pm
by Grrrmachine
If you've swapped the SI batteries with known good ones, and you're absolutely sure the black wire is giving a clean signal from the ECU to the clock, then either your clock itself is broken or your engine isn't actually turning.
Posted: Mon Jul 08, 2013 5:26 pm
by frenchi
thanks for that I understand what you have wrote,i suffer from dislexier .its hard to understand and red some stuff ,I have tried the site but some stuff wont come up I don't think I have the right hard where,i will have another go tomorrow I think the signal is trying to get through that's why the needle was jumping ,thanks again, rick
