power roof not going all the way
Posted: Fri Jul 05, 2013 7:17 pm
by dazzo
hi can anyone give me any ideas on how to get my roof to go into the back and the horseshoe to close completly i have only just brought the car so have very little knowledge so all help appreciated thanks
Re: power roof not going all the way
Posted: Fri Jul 05, 2013 8:37 pm
by Gert_8
Can you go through the sequence of what the roof is doing.
Posted: Sat Jul 06, 2013 2:35 pm
by dazzo
Gert_8 wrote:Can you go through the sequence of what the roof is doing.
when you put all windows down ,moved sun visors when you press the button you have to give the roof a helping hand then the horse shoe lifts the window folds back at the rear and most of the time the roof goes back and fits into the opening but doesnt seem to fit all the way in seems to be 2" to big then the horse shoe closes not all the way as the roof sticking up above the opening hense the horseshoe cannot close it will go down a little after you drive around but never enough for the horseshoe to close completly hope this explains my problem thanks
Posted: Sat Jul 06, 2013 4:37 pm
by Gert_8
Hi. Firstly, what you're describing is quite a common problem. I'd also like to mention, after putting the windows down and releasing the front securing latches, under the sun visors, you should ALWAYS push the roof back to begin.
If you don't do this and activate the switch to fold
It back, you are putting an enormous amount of pressure on the roof motors and linkages. You are lucky not to have broken something, already.
Your roof sounds like it is working fine. The problem may have something to do with the way the roof is actually folding. With some roofs, the tensioner straps are not pulling the front (first) fold so that it folds up (in an "n" shape) the correct way. It actually folds it going down in a "u" shape. This fold can catch on the rear headrests - if you have them fitted, but it also makes the roof "thicker" accounting for your 2", if you understand what I mean.
There is a thread on here were this problem is described, complete with pics and the
Solution. I will search for it on Monday, when I have my laptop (currently responding on my phone).
Sorting this out first, will allow the roof to be
More compact when it's folding into the storage compartment. This then should
Help the
Horseshoe close better, if not fully.
Try that first, or confirm that that is what the roof is doing, after which we can talk about adjustment to the closing levers, if required.
Can you post some pics. It is also relevant to know whether your roof is new or old.
Posted: Sat Jul 06, 2013 10:09 pm
by dazzo
Gert_8 wrote:Hi. Firstly, what you're describing is quite a common problem. I'd also like to mention, after putting the windows down and releasing the front securing latches, under the sun visors, you should ALWAYS push the roof back to begin.
Help the
thanks for that if you can get me the thread would be great sounds like its what your saying
Posted: Mon Jul 08, 2013 10:59 am
by Gert_8
Hi Mate,
Have a read of this, I think it should solve your problem.
http://www.e30zone.net/modules.php?name ... c&t=195689
Posted: Mon Jul 08, 2013 7:33 pm
by dazzo
sounds good will give it a go and let you know how i get on thanks for your help
by dazzo
Posted: Sat Jul 27, 2013 12:33 pm
by dazzo
dazzo wrote:sounds good will give it a go and let you know how i get on thanks for your help
tried what you suggested but when my mate came to help he showed me it was because the stiching has come undone on the roof hence the front of the roof is not folding correct causing the problem, looks like getting my new roof sooner than I thought .
