Diff removal
Posted: Sat May 18, 2013 5:22 pm
by Andy-M
Any top tips on getting the top two retaining bolts undone. There no room to get my big bar between the top of the bolt and the floor. Even swearing at it didn`t work........
Re: Diff removal
Posted: Sat May 18, 2013 5:29 pm
by Grrrmachine
Ring spanner, then a second one locked on to it as an extension.
Re: Diff removal
Posted: Sat May 18, 2013 5:31 pm
by jimbom30cab
with lots of WD40
Re: Diff removal
Posted: Sat May 18, 2013 5:37 pm
by maxfield
Grrrmachine wrote:Ring spanner, then a second one locked on to it as an extension.
That!
They will be tight and there's a good chance your going to skin your knuckles.
Re: Diff removal
Posted: Sat May 18, 2013 8:43 pm
by Andy-M
Panic over....... Lol.
Found a mug of PG and a couple of chocolate Hobnob`s did the trick......
Heavy bugger when it slid off the jack and landed on my arm.
How can something so small be the weight as a small planet...
Re: Diff removal
Posted: Sat May 18, 2013 11:39 pm
by Shmallpaul
The real fun is getting it back on again!
Re: Diff removal
Posted: Sat May 18, 2013 11:45 pm
by Rav335uk
I hope you put alittle bit of Loctite on the 4 bolts.
If you can't torque them up, it helps, as they have been know to work loose.
Re: Diff removal
Posted: Sun May 19, 2013 9:33 am
by Shmallpaul
I can vouch for this.. as I found the source of my clunking sound when shifting was due to one of these suckers completely coming out, and the other about 3/4 there
