Some paint prepping questions.
Posted: Thu May 02, 2013 1:56 pm
Just wondering if this is a good strategy for derusting and treating the inner arches. The worst of the back arches has rust and a couple of small holes so what I'm planning is:
To take the affected areas back to metal with the grinder/wire brush/elbow grease, weld where necessary, treat surface with jenolite, spray zinc rich primer, then a couple of coats of POR 15 brushed on.
That's a basic outline of what I plan to do for the inner arches and other out of sight areas infected areas (sills, floor pan, battery trey recess etc. Is this a good approach? Any tips would be welcomed, thanks.
