Rear anti-roll bar drop links
Posted: Sat Apr 27, 2013 9:20 pm
by e30nerd
Is there a technique for fitting the drop links to the rear ARB?
I'm having difficulty sliding the link on to the end of the ARB, ie the top of the drop link. I'm doing it in situ rather then removing the bar completely. The N/S took me a few hours but eventually went. The O/S rear is being a PITA.
Room is tight as I'm working behind the spring. I've tried using washing up liquide the help lube, I've tried heating the end of the droplink in hot water.
I've tried pushing on by hand but it is too tight. I've also tried trying to hook a G clamp behind the roll bar where in bends to 90 degrees to the drop link and using the clamp to slowly 'work' link on to the end of the bar but no luck.
Has anyone had a better luck with this?
Re: Rear anti-roll bar drop links
Posted: Sat Apr 27, 2013 9:42 pm
by gromgsxr
Pull the spring out more room to get in there did a set last night
Posted: Sat Apr 27, 2013 10:30 pm
by e30nerd
Thanks Gromgsxr, that will help. It's wired but the N/S took ages then suddenly went. Having got that side done I was hoping the O/S follow suit.
Did you just push them on by hand?
Posted: Sat Apr 27, 2013 10:32 pm
by Motorhole
Plenty washing up liquid on the rubber and they will push in by hand.
Posted: Sun Apr 28, 2013 7:14 am
by daimlerman
Make sure that the end of the ARB is spotlessly clean.
Posted: Sun Apr 28, 2013 9:04 am
by Grrrmachine
Posted: Sun Apr 28, 2013 8:06 pm
by e30nerd
Thanks all
Got it fitted in the end - I managed without moving the spring but it was tight. I used a large G clamp to exert pressure on the end and then gently wiggled the drop link using my other hand to work it down the bar.
Thanks everyone for their input.
