Removing paint from Tech 1 spoiler
Posted: Sat Apr 27, 2013 5:46 pm
by markmadman2
Sorry if this is in the wrong section.
I have received a tech 1 spoiler that has had the rubber painted which is starting to peel off (in places but very much stuck on in others. Anyone know of a safe way to strip the paint to restore it back to it's unpainted conditon. Most of the stuff strong enough to eat the paint would also eat the rubber but there must be a way.
I have tried picking/peeling ect but to no avail
Re: Removing paint from Tech 1 spoiler
Posted: Sat Apr 27, 2013 6:02 pm
by Sanchez
What about some brake fluid?
Posted: Sat Apr 27, 2013 6:17 pm
by markmadman2
Tried it on a already damaged one i have and it ate into it
Posted: Sat Apr 27, 2013 7:40 pm
by matt86
G3, then coat in linseed oil to protect it, be careful with the g3, when you get down to the rubber.
Posted: Sun Apr 28, 2013 12:04 am
by markmadman2
Thanks Matt, have used linseed oil years ago and flamable is an understatement lol. I'll try and get some G3 (scratch remover i presume)and LO and give it a try
Posted: Sun Apr 28, 2013 12:23 am
by 811
i used a heat gun to get the paint off a side pod.. could try that if all else fails.. plastic was ok but don't know if the rubber would stand the heat??
Posted: Sun Apr 28, 2013 12:26 am
by markmadman2
Yeah that was my problem knowing how ridiculously easy it is for the rubber to damage,i used low to medium heat on it and it did nothing
Posted: Sun Apr 28, 2013 12:52 am
by 811
you still got the damaged one? could you try more heat on that to see what it could take?
Posted: Sun Apr 28, 2013 10:46 am
by matt86
markmadman2 wrote:Thanks Matt, have used linseed oil years ago and flamable is an understatement lol. I'll try and get some G3 (scratch remover i presume)and LO and give it a try
I'm also told smooth peanut butter, will bring the shine back and protect it
Try g3, or maybe a rubber scraper to rub it off without damaging the rubber ie ice scraper type thing
