Diff issues.. pictures!
Posted: Tue Apr 16, 2013 11:36 pm
So I've been having this knocking sound when changing gear (mostly from 1st-2nd, or 2nd-3rd) also u can kinda hear the diff moving a little bit when coming off the power etc, at first this was barely noticeable, now as its getting worse decided to jack her up and take a look.
So first concern, the bolts that hold the diff straight up at the top at the back (the ones that are impossible to reach and cant be seen from underneath) one of those is missing
and the other is about 1cm unscrewed. Tried tightening it but after half an hour of swearing and cursing the sucker wouldn't budge either way (can't be moving about too much then..?)
Does anyone know the part number for my missing bolt?
Second problem is that one of the driveshafts appears to be a cm or so further away from the diff than the other one, and has some green goop dripping off it, would this be diff fluid? See terrible pictures!
Thirdly seem to have a loose cable tied up to the speedo sensor on the diff? Guessing not important? Least of my concerns after this discovery anyway
Any help is very appreciated!
terrible closeup of leaky driveshaft/diff
and the mystery cable, so professionally tied on to the speedo sensor diff pluggy bit cable
