M50 Problems, misfire
Posted: Tue Apr 02, 2013 7:49 pm
Hi, Hopefully somebody can give me an idea of where to look next,
First the car started to misfire a little not all the time, and under load in lower revs and a little at the top end but loss often.
First i cheched all plugs, which were badly worn so, cleaned them up for the nxt day and did seem to help, but now since fitting new plugs (same ones) it seems to of got worse, misfireing and what seems like a preignition.
Have tested coils and cleaned contacts, All read the same resistance between outer pins.
Have since tried it running with o2 and maf unpluged at seperate times with no change other than poor idle.
other symptom which was there before is its flat as a dodo, which i put down to the vanos being buggered.
Any help appreciated, have also looked over for split pipes but couldnt find any.
