steering
Posted: Thu Mar 07, 2013 5:51 pm
by torquey
My steering wheel has just developed a horrendous squealing noise,can anyone shed some light on what the cause may be,Thank you.
Re: steering
Posted: Thu Mar 07, 2013 6:59 pm
by Rtaylor2208
Most likely dry bearings in the steering column. I think there is a wiki article detailing how to drill a hole close to the bearing to oil it up.
Unless the squeal is commin from the engine bay which would be a loose pas belt.
Re: steering
Posted: Thu Mar 07, 2013 7:30 pm
by 811
pas? fluid level? my truck made terrible noise with low fluid level
Re: steering
Posted: Thu Mar 07, 2013 7:42 pm
by parkin10
went to all the trouble of changing the rack to cure that noise to find it was the column bearings
oil em first :snigger:
Re: steering
Posted: Thu Mar 07, 2013 8:07 pm
by Brianmoooore
There's also the carbon brush for the horn push connection. Although carbon theoretically needs no lubricant, in this case it does.
Re: steering
Posted: Thu Mar 07, 2013 8:21 pm
by torquey
Brianmoooore wrote:There's also the carbon brush for the horn push connection. Although carbon theoretically needs no lubricant, in this case it does.
Cheers Brian,excuse my ignorance how do go about the process of lubricating the brush :?
Re: steering
Posted: Thu Mar 07, 2013 8:46 pm
by JF008
suscribed
Re: steering
Posted: Thu Mar 07, 2013 8:50 pm
by balilu91
i m also interested in the horn carbon push noise. I had the squeal fixed with some copper grease but the horn is now working only when going around a corner.. probably made too much grease maybe.
whats the appropriate way to fix this?
Re: steering
Posted: Fri Mar 08, 2013 12:15 am
by Brianmoooore
balilu91 wrote:i m also interested in the horn carbon push noise. I had the squeal fixed with some copper grease but the horn is now working only when going around a corner.. probably made too much grease maybe.
This is often lack of lubrication in the lower column bearing, through which the inner column earths to the body. WD40 from the engine bay, followed by grease.
Re: steering
Posted: Fri Mar 08, 2013 12:16 am
by Brianmoooore
Remove steering wheel and apply a spot of grease to the brass ring on the rear of the boss.
