rear brakes spring kit
Posted: Sun Feb 17, 2013 10:51 pm
by asmith88
is there any difference between the spring kit for rear drums amd rear discs?
Re: rear brakes spring kit
Posted: Sun Feb 17, 2013 11:02 pm
by Brianmoooore
Yes.
Posted: Sun Feb 17, 2013 11:07 pm
by asmith88
any way of telling before i try to fit it, I have a kit here but I have no idea if it is for drums or discs
Posted: Sun Feb 17, 2013 11:27 pm
by Brianmoooore
The drum brake kit parts are much beefier than the kit for disc handbrakes, which doesn't help all that much unless you have both parts to compare.
The disc handbrake kit should have two retaining springs and pins plus two coil springs with hooked ends.
Drum brake kit should be two separate kits for retaining springs and shoe springs. Retaining spring kit should have pins, springs plus washers that the pins pins fit into, and the spring kit should be three springs with hooked ends.
Posted: Sun Feb 17, 2013 11:36 pm
by asmith88
well there is four springs in this kit so I assume it is the correct one for discs,
cheers brian
