stud extractor
Cloggy Saint
Das_BMW_E30
Two nuts are the usual piece of kit.
Depends if the studs are intact, rusted in or broken off
maxfield
That used to be the way I did it, until I used a stud extractor.DanThe wrote:Two nuts are the usual piece of kit.
Very handy tool.
Das_BMW_E30
Snapped exhaust studs, in ally heads....
Put a nut over the broken stud, weld up the inner of the nut to the top of the broken stud, and then just fit a spanner and unwind...
The heat generated lets the broken stud unwind...
maggspower
- Turbo Farmer Tractor Driver
Roller stud extractors are good, but they wont get stuck ones out. For that you need 2 nuts, 2 spanners, and some heat and time. Remember if it takes half an hour to get one stud out intact, that is a good time saving on getting a broken one out.
I use one of these for scrap studs -
http://www.toolbuddy.co.uk/franklin-imp ... -948-p.asp
You wont be able to reuse them after though which is where two nuts and spanners come into it
A point that I frequently try to impress on my current 'apprentice', but, with the impatience of youth, is often ignored!maggspower wrote: Remember if it takes half an hour to get one stud out intact, that is a good time saving on getting a broken one out.
Topblag
I've got the Irwin set and thus far they have taken out every one I've set them on to. I've just bought the additional ones to make up the complete set.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Cloggy Saint
I don't have any broken (yet) or stuck studs, I just want the right tool for the job.
http://www.ebay.co.uk/itm/Irwin-Bolt-Gr ... 20cb732f5a
Like this one?Topblag wrote:I've got the Irwin set and thus far they have taken out every one I've set them on to. I've just bought the additional ones to make up the complete set.
Topblag
That's the ones. Best example was a rounded bolt on a drop link, which had also been attacked with a grinder so the bolt was not only rounded, there was only about 3mm left on it. 6 point socket would grip it but couldn't get enough purchase to turn it. Irwin remover took it off in seconds.
shedrool83
Lurch320i
What about an exhaust stud that has snapped flush with the head?is drilling and helicoil the only way to get it out
- **BANNED**
So you are looking for an answer to a problem that does not,yet, exist?Cloggy Saint wrote:I don't have any broken (yet) or stuck studs, I just want the right tool for the job.
Das_BMW_E30
Lurch320i....Snapped exhaust studs, in ally heads....
Put a nut over the broken stud, (even when it's flush with the head) weld up the inner of the nut to the top of the broken stud, and then just fit a spanner and unwind...
The heat generated lets the broken stud unwind...I have seen this carried out on a Sierra Cosworth Head, with numerous broken studs...very effective.
maggspower
I agree with the above. If you are just doing your own head just use the 2 nut technique, it should get them all out with some patience.daimlerman wrote:So you are looking for an answer to a problem that does not,yet, exist?Cloggy Saint wrote:I don't have any broken (yet) or stuck studs, I just want the right tool for the job.
I think we are a crossed purposes as well with the term "stud extractor". I think the type th OP is talking about is ones for getting intact, good condition studs out. Not "easy outs" or the ones for fooked studs, snapped, or round headed bolts.
IMO you would be better off getting a heat source, like a propane/mapp gas blow lamp, as this WILL loosen stuck studs so they can be removed using the 2 nut method, and is no end of use elsewhere too.
