Oil light flickering an some times staying on
Posted: Sun Dec 23, 2012 9:22 am
by imye30
E30 325i convertible while station the oil lights is off then start to drive it starts to flicker or stay on for ten sec or more checked the oil level that's all good
Re: Oil light flickering an some times staying on
Posted: Sun Dec 23, 2012 9:58 am
by Brianmoooore
Three possibilities: a) Your engine is clapped*, b) the oil pressure switch is defective, or c) the insulation has cracked on the wire to the oil pressure switch where it goes around the front of the engine, and is shorting to earth.
*BMW actually state that the light coming on is acceptable at idle, but doubt if anyone looking to buy your engine would agree.
Posted: Sun Dec 23, 2012 11:57 am
by Andyboy
Fourth option: idle speed is too low.
Posted: Sun Dec 23, 2012 12:02 pm
by BenHar
Andyboy wrote:Fourth option: idle speed is too low.
Wrong if you read the OP properly.
He says it comes on when he drives not at idle.
Ben
Posted: Sun Dec 23, 2012 5:45 pm
by Andyboy
BenHar wrote:Andyboy wrote:Fourth option: idle speed is too low.
Ben
Sorry to have offended you.
Posted: Sun Dec 23, 2012 6:42 pm
by BenHar
Not offended at all. And no offence meant, sorry.
Just didn't want the OP chasing the wrong solution.
Ben
Posted: Sun Dec 23, 2012 6:58 pm
by steve_k
option B from mr mooooooore, had this happen to me a while back, the sensor was failing & oil was dripping out through it.
replaced the sensor & it's been good as gold since.
just make sure you replace the little O ring at the same time.
Posted: Sun Dec 23, 2012 7:47 pm
by imye30
Also just noticed engine sound s rattley at sertain revs mite be on its way out
Posted: Sun Dec 23, 2012 7:57 pm
by steve_k
imye30 wrote:Also just noticed engine sound s rattley at sertain revs mite be on its way out
that could just be the tappets
Posted: Sun Dec 23, 2012 8:07 pm
by imye30
Ya could be but does not sound good to me will have to see an make sure nothing is loose but only started this noise since the oil light prob
Posted: Sun Dec 23, 2012 8:40 pm
by imye30
Is the oil sensor east to replace we're is it located
Posted: Sun Dec 23, 2012 8:45 pm
by maggspower
imye30 wrote:Is the oil sensor east to replace we're is it located
It is easy to replace, but you will need a 24mm (i think) deep socket, or simular size ring spanner, the latter will have to have a thin wall though.
Posted: Sun Dec 23, 2012 8:54 pm
by imye30
Just looked at the sensor there are 2 types one had a pin an other as a plug in type from gsf
Posted: Sun Dec 23, 2012 9:06 pm
by Brianmoooore
Early engine and later engine. Actual sensors are the same, but the connector is different.
Buy whichever type is fitted to your engine.
Posted: Sun Dec 23, 2012 9:22 pm
by steve_k
maggspower wrote:imye30 wrote:Is the oil sensor east to replace we're is it located
as byron says 24mm deep socket, extension bar & also while your there you might aswell give it an oil & filter change as there WILL be plenty of old oil dribbling out.
Posted: Sun Dec 23, 2012 9:55 pm
by imye30
Ok cheers guys next on the list this noise could be a loose tappet
Posted: Mon Dec 24, 2012 7:46 am
by Andyboy
imye30 wrote:Also just noticed engine sound s rattley at sertain revs mite be on its way out......only started this noise since the oil light prob
I would hazard a guess and say it's shagged.
