interior light delay relay
Posted: Fri Nov 25, 2005 11:47 pm
by DazzyA
After the part number if any one can help.
Posted: Fri Nov 25, 2005 11:56 pm
by smithy318i
there are 2 part numbers
one is 61311373974
I cant remember the other.
Posted: Fri Nov 25, 2005 11:57 pm
by DazzyA
have you got any left mate
Posted: Sat Nov 26, 2005 12:02 am
by smithy318i
trying to deal with a small backlog at the moment.
Posted: Sat Nov 26, 2005 12:10 am
by DazzyA
ok, thanks for the info mate.
Posted: Sat Nov 26, 2005 10:29 am
by Brianmoooore
smithy318i wrote:there are 2 part numbers
one is 61311373974
61311380233 is the older part no. Can be found in the occasional E28 five series, near the bottom of the steering column, IIRC.
Posted: Mon Jul 03, 2006 2:36 pm
by Sharknose3
Smithy318i, Brian,
I ordered the 61311373974 part from a guy in Germany and he sent me the following: 5 HE 003 79511373975.(Zeitsteuer-Geraet 12V) Looks like it came out of an E23.
Can I assume that it is unusable in an E30?
I've already asked him to take this back and send me the correct one.
Thx in advance,
Sharknose
Re: interior light delay relay
Posted: Mon Jul 03, 2006 7:46 pm
by smithy318i
Sharknose3 wrote:Smithy318i, Brian,
Thx in advance,
Sharknose
a fully loaded E32 has the soft fade delay circuit which stayed on for 10 secs or so.
Posted: Mon Jul 03, 2006 8:29 pm
by Brianmoooore
The E23 circuits show a timer that could be used on an E30, but I don't know if it fits the same socket.
Posted: Mon Jul 03, 2006 8:51 pm
by jcjdavis1
I purchased a light delay switch from a car acces. shop for a couple of pounds works perfect.
Posted: Tue Jul 04, 2006 11:17 am
by Sharknose3
Here's an update on this,
I fitted the thing this morning and it works perfectly - 8 second delay.
Apart from the wire swap on the door switch I needed to scotch lock the Tg & Tk wires together as advised by
Smithy318i
Here is the clarification I got from the German provider of the part:
The function of 374 and 375 is the same, the difference is in the output power the part can take.
375 is up to 40 Watt ( 4 x 10 watt lamp ), 374 only 20 Watt.
795 is the Hella Identification, Hella has been building only the stronger 40 Watt type for years now.
If anybody wants to source more of these he seems to have more in stock and charges ┚¬15 + ┚¬8.50 postage + 5% for Paypal.
His name is Michael, you can mail him on
Xmichnowakx@aol.com
Hope this information is useful to somebody,
One question : -
The delay works on the drivers door switch but not on other doors. Is the wiring of my door switches not as it should be?
Thanks for all the help,
Sharknose
Posted: Tue Jul 04, 2006 9:59 pm
by Brianmoooore
Sharknose3 wrote: -
Sharknose
Interesting info, there!
Drivers door only is how it should be. Very strange of BMW to decide the passenger doesn't need the delay.
I correct this by running a wire from the passengers door switch, (disconnect existing wire) to the wire connected to the driver's door switch.
Posted: Tue Jul 04, 2006 10:01 pm
by smithy318i
is it "soft off" or just ...OFF
Posted: Tue Jul 04, 2006 10:53 pm
by DanThe
Brianmoooore wrote:Very strange of BMW to decide the passenger doesn't need the delay.
What about if you were dropping a passenger off on the side of the road, you wouldnt want the lights still on after you had already driven off would you
Posted: Tue Jul 04, 2006 10:56 pm
by Brianmoooore
DanThe wrote:Brianmoooore wrote:Very strange of BMW to decide the passenger doesn't need the delay.
Possible they were thinking something like that, but it's only about six seconds.
Posted: Wed Jul 05, 2006 9:34 am
by Sharknose3
It is not "Soft off", just "off" but I'm happy that it delays 8 seconds.
I'll drop Michael in Germany an email to see if he has a "soft-off" relay with the same pinout as the one I just fitted. He specializes in E23s- here is his website:
http://hometown.aol.de/xmichnowakx/home ... motor.html
Sharknose
Posted: Wed Jul 05, 2006 2:35 pm
by smithy318i
if the engine is running, the light switches off when you shut the door.
Posted: Wed Jul 05, 2006 10:15 pm
by Sharknose3
I just heard back that a relay with soft-off for the E23 model was never availible,
Sharknose
Posted: Wed Jul 05, 2006 10:28 pm
by DanThe
smithy318i wrote:if the engine is running, the light switches off when you shut the door.
They actually DO think of everything
Posted: Wed Jul 05, 2006 10:30 pm
by stevetigger
Thats true! Lights go out if ignition is on!
Interior light delay
Posted: Fri Jul 14, 2006 4:51 pm
by Sharknose3
The following is another 8 second delay relay that I've tested on an E30 :
5HE 003 795-01 1369 417 (Zeitsteuergeraet 12V) [262]
Sharknose
Posted: Fri Jul 14, 2006 5:29 pm
by Morat
My interior lights don't come on when the doors open
The interior light in the boot behaves perfectly.
Where should I be looking?
Posted: Fri Jul 14, 2006 10:13 pm
by smithy318i
Morat wrote:My interior lights don't come on when the doors open
firstly check the position of the switch on the dome light.
secondly remove and clean the contacts on the door switches.
report back if that doesnt fix the fault.
