oil coolers needed with modern oil ??
Posted: Wed Nov 23, 2005 10:42 pm
by exup
Are oil coolers still required with modern oils??
i m doing a 2.7 conversation , and wondered about fitting a 325 one ?
is the 325 one fitted with a thermostat to only open once oil up tp temp ??
Posted: Thu Nov 24, 2005 8:05 am
by Turbo-Brown
Sure is
Posted: Thu Nov 24, 2005 8:45 am
by stappin
Anyone know where to get new oil coolers for the 325i or is there an off the shelf replacement?
Posted: Thu Nov 24, 2005 9:15 am
by Demlotcrew
BMW dealers/ECP/GSF will sell them, i would use them only if you drive the car really hard.
Andrew
Posted: Thu Nov 24, 2005 9:57 am
by Steviec
Or you can get aftermarket ones here:
http://www.rallydesign.co.uk/catalog/ad ... =2a&page=1
They seem quite a good price too.
Posted: Mon Nov 28, 2005 1:42 pm
by oilman
It depends on the oil temps measured in the sump.
Simon
Posted: Mon Nov 28, 2005 3:31 pm
by Templ8e30
I too have 2.7 conversion and have fitted the oil cooler from a 325i.
Before I fitted the oil cooler during an oil change I scalded my hand with the oil. I do drive it pretty hard but this oil was so hot that my cheapo drain pan went a bit floppy and that's with Silkolene Pro-S synthetic oil.
Since fitting the oil cooler I have noticed a drop in running temperature as well as a drop in oil consumption. I was using a litre per 4000 miles, whereas I now use about 1/4 litre in 4000.
After a hard run I can feel the temperature difference from one side of the cooler to the other. Very effective.
I also noticed a difference when I swivelled the oil cooler take-off plate round 180 degrees. Normally the oil filter sits close to the exhaust manifold/downpipes so turning the plate through 180 sits the oil filter towards the front of the engine keeping it cooler and also making it easier to get to.
I have a habit of fitting a neodymium magnet on the end of my filters to contain any metal fragments inside the filter so I can be sure they are removed when the filter is changed.
Cheers,
Iain T
