Oil - You get what you pay for!
Posted: Mon Nov 21, 2005 4:11 pm
A word of caution Ԛ—a You get what you pay for!
Below is an article written by John Rowland, Silkolene/Fuchs Chief R & D Chemist for 40 years.
Quote:
Costs of synthetics vary considerably. The most expensive are the Ԛ“EsterԚâ€a types originally only used in jet engines. These cost 6 to 10 times more than high quality mineral oils. The cheapest synthetics are not really synthetic at all, from a chemists point of view. These are in fact specially refined light viscosity mineral oils known as Ԛ“hydrocrackedԚâ€a. These have some advantages over equivalent mineral oils, particularly in lower viscosity motor oils such as 5w-30 or other oils with a low Ԛ“WԚâ€a rating such as 5w-50 etc and they cost about 1.5 times more than good quality mineral fractions.
We use several different grades of this base oil, where appropriate. This is the Ԛ“syntheticԚâ€a which is always used in cheap oils that are labelled Ԛ“syntheticԚâ€a.
Yes itÔš's a cruel world, you get what you pay for!
Now, you may ask, why are these special mineral oils called Ԛ“syntheticԚâ€a?
Well, it was all sorted in a legal battle that took place in the USA about ten years ago. Sound reasons (including evidence from a Nobel Prize winning chemist) were disregarded and the final ruling was that certain mineral bases that had undergone extra chemical treatments could be called Ԛ“syntheticԚâ€a.
Needless to say, the marketing executives wet their knickers with pure delight!
They realised that this meant, and still does, that the critical buzz-word Ԛ“syntheticԚâ€a could be printed on a can of cheap oil provided that the contents included a few percent of Ԛ“hydrocrackedԚâ€a mineral oil, at a cost of quite literally a few pence.
So, the chemistry of Ԛ“syntheticsԚâ€a is complex and so is the politics!
The economics are very simple. If you like the look of a smart well-marketed can with Ԛ“syntheticԚâ€a printed on it, fair enough, it will not cost you a lot; and now you know why this is the case.
But, if you drive a high performance car, and you intend to keep it for several years, and maybe do the odd Ԛ“track dayԚâ€a, then you need a genuine Ester/PAO (Poly Alpha Olefin) synthetic oil.
This oil costs more money to buy, because it costs us a lot of money to make, very simply, you always get what you pay for!
Unquote:
This article is something that all car owners should read and understand before buying oil and IÔš've posted this with Johns permission.
Simon
Unquote:
Simon
