fuel pump humming
Posted: Sun Nov 20, 2005 4:30 pm
by ac
Dose any one know if it's normal for the fuel pump to hum quiet loud on a 318i cab 92 spec.
Both when idleing and driving.
Ac
Posted: Sun Nov 20, 2005 4:50 pm
by michael24m
:? mine too, same idleing and driving. whatever you do don't replace it with a pump for a diffrent engine than 318, i tried this and didn't work, the engine didn't start. i put my old one back in and still driving with it. the sound, goes away and sometimes comes back humming i just ignore it.
fuel pump
Posted: Sun Nov 20, 2005 4:52 pm
by dasparkybad
fuel pumps usually become noisy when the motor bearings begin to fail maybe time for a new one before it fails completely
Posted: Sun Nov 20, 2005 4:56 pm
by ac
thanks.
ac
Posted: Sun Nov 20, 2005 4:58 pm
by Simon13
yes once they get loud they are no longer for this world. I had one go on me on my old 318i not fun!
Posted: Sun Nov 20, 2005 5:17 pm
by eko
Mine too was very loud,bought one off " DAN318is" and its been perfect ever since!
Took about half hour to change,very easy job :)
Posted: Sun Nov 20, 2005 6:43 pm
by Simon
I also had a buzzing pump, and changing it for a new one made a noticable difference.
Fuel pumps are common through the E30 range as long as the injection systems are the same.
Micheal, can't understand why yours didn't work, dodgy pump?
Posted: Sun Nov 20, 2005 7:52 pm
by michael24m
i have the 320i engine, and replaced the pump with a 318i pump, same injection model L-jetronic. i seen the 318 drive that day before i took out it's pump and put it in mine.
on the 318 worked wonders not a sound. but when installed on mine, cranked for half a day, couldn't manage to start the engine.
put in my old pump and started from the first key turn, so obviously there was a problem fitting a 318 pump on a 320i :? i think it might have been a pressure diffrence problem.
Posted: Mon Nov 21, 2005 4:32 pm
by haffeel
guys, my fuel pump also makes whining noise at high pitch. I notice when I just come to a hault after a long jurney and did not cut off the engine. when I put down the windows the sound is very obvious.
my ride orignially is a 320i and I have done a 325i conversion.
Are the fuel pump for 320i and 325i are same?
or do I have to install a 320i pump once again as thats the original spec right now?
what ever, I am pretty scared going off long distance. I would like to carry a spare fuel pump for what ever reason.
TQ
Posted: Mon Nov 21, 2005 5:37 pm
by Simon
haffeel wrote:guys, my fuel pump also makes whining noise at high pitch. I notice when I just come to a hault after a long jurney and did not cut off the engine. when I put down the windows the sound is very obvious.
TQ
If the car is a motronic then they are the same....even the same as 316i/318i, the pressure is regulated by the erm fuel pressure regulator :lol:, but I'm not sure about the L-jet cars.
Posted: Tue Nov 22, 2005 3:31 pm
by haffeel
thanks, yes mine is a Motronics 173 series aka 1.3 so I can fix in 320, 325, 318 or 316 great.
