Compression test question
Posted: Sun Nov 20, 2005 2:13 pm
by OllieB
Just about to do a compression test on my car, anyone have any idea what sort of compression I should be hoping for? It is a 1989 tech 2 sport. Cheers guys....
Posted: Sun Nov 20, 2005 4:02 pm
by OllieB
Anyone......?
hi
Posted: Sun Nov 20, 2005 4:50 pm
by touring170
not sure on the ratio but to get a good test result u need to test it a normal operating temp.i tested mine cold and thought the engine was dead on a few but it fired up first time with no trouble.
Posted: Sun Nov 20, 2005 4:59 pm
by tylerma
gonna move this into tech help dude
test
Posted: Mon Nov 21, 2005 9:21 am
by ajay31
to do the test warm engine.
be careful where you put fingers hands and arms.
readings should be similar across all the pots.
if there is any problems it will normally show on one, maybe two pots and the readings will be way off the mark from the rest.
hope this helps fella and good luck.
Posted: Mon Nov 21, 2005 10:23 am
by OllieB
Burnt my frostbitten fingers on the bloody manifold and lost my temper. Gonna try again today at some stage, will post results...
