Changing ignition barrel
Posted: Thu Jul 26, 2012 12:03 pm
by TobagoBlueBM
Alrite people
Well I've lost my keys so I have got to change the locks! I was wondering how hard it's going to be to get the ignition out without the key in. Any help or tips would be appreciated
Re: Changing ignition barrel
Posted: Thu Jul 26, 2012 12:32 pm
by Barx325i
righty you'll need a hair clip, (you can use wire, but it's a faff) remove the blob, straighen it out. You'll be using the straighter back section, so with decent pliers, straighten the slight bend out at the end and re-bend approx 1.5-2mm by 30-40 degrees.
key in, turn to position 1 and insert the hair clip with the bend facing away from the centre. push it in about 5cm and turn it through 90deg in the same way yo'd turn the key. You'll know when you're in the right place as you'll feel a light sprung resistance and it'll go loose and slide out
Posted: Thu Jul 26, 2012 12:49 pm
by daimlerman
With no key to insert into the barrel,you are going to have to swap the entire lock.
Remove the steery wheel
Remove the lower column shroud
Using a suitable impliment winkeye extract the shear bolts that retain the lock to the column
Posted: Thu Jul 26, 2012 12:52 pm
by Barx325i
whoopsie, did I do a Polsta :o:
Posted: Thu Jul 26, 2012 1:23 pm
by greggers
Can you get the steering wheel off with the steering lock on and without breaking anything... I seem to remember I couldn't when I tried a few weeks ago.
Posted: Thu Jul 26, 2012 1:43 pm
by Rich320I
doesnt the key have to be in the barrel in position one to release the wheel in the first place? so if you have no key that would be impossible?
Posted: Thu Jul 26, 2012 2:05 pm
by daimlerman
Barx325i wrote:whoopsie, did I do a Polsta :o:
Me too!
Perhaps some chopping of the column shroud will be called for to access the lock mounting bolts,then let it slide down to release the wheel?
Posted: Fri Jul 27, 2012 9:25 am
by Brianmoooore
What's wrong with taking the paperwork for the car to BMW and ordering a new key?
If the lock isn't the original, then the barrel is useless anyway, so I think I'd be attacking it in situ with a drill, hopefully removing the remains of the tumblers, then turning the butchered barrel to position one and extracting it with a pin.
by pacerpete
Tut tut ! stand in the corner and liberally apply FERTAN to your genitalia whilst wearing a paedo coat :)
Posted: Fri Jul 27, 2012 9:44 am
by Jim320i
Wouldnt that just be his normal coat? :D
Posted: Fri Jul 27, 2012 9:57 am
by Andyboy
To get the wheel off with no key - insert a hacksaw in the gap between the uppewr column shroud and the wheel. Saw away for about 5 mins and you'll cut through the steering lock pawl. The wheel will them come off and you can fit a replacement steering lock.
