prefacelift 325 injector part number
Posted: Mon Jul 23, 2012 11:18 am
by Prey
anyone help me out with this? trying to find out a part number for the above. it's a c plate (1985) 325. if someone has access to this kind of info that would be a huge help.
Re: prefacelift 325 injector part number
Posted: Mon Jul 23, 2012 11:27 am
by Jim320i
13 64 1734776 - realoem
0280 150 710 - Bosch
Thats what I get from Realoem, then a google search
Posted: Mon Jul 23, 2012 11:43 am
by Prey
cheers for that mate, it confused me a bit cause realm lists it as 13641734776 but then googling it seems to show that part number being for a 1989 (so facelift). i thought pre and post facelift would be different injectors?
Posted: Mon Jul 23, 2012 11:46 am
by Jim320i
Those injectors are used on the following
BMW 83-85 318i
BMW 87-91 325i
BMW 88-91 325iC
BMW 87-91 325iS
BMW 88-91 325iX
BMW 89-90 525i
BMW 88-96 750iL (M70)
BMW 95 850LSi (M70)
So, i'm guessing there isnt much different with regards to pre & facelift :D
Posted: Mon Jul 23, 2012 11:49 am
by Prey
ah ok that's good, looks like i have a spare set in that case then!
there doesn't seem to be much reference to the really early ones for some reason so i got a bit paranoid ha ha.
Posted: Mon Jul 23, 2012 12:06 pm
by Grrrmachine
There's a difference between Jetronic and Motronic injectors, but since ALL 325's (including prefacelift) ran a version of Motronic, the injectors should be compatible.
The injector impedance issue is with 320's, or upgrading a 323i to Motronic.
Posted: Mon Jul 23, 2012 2:30 pm
by Prey
just found out the ones i was looking at are from a 1990 320, so definitely would be no good for an 85 325?
