MOt time - How to fit front wheel bearings???
Posted: Mon Apr 16, 2012 1:21 pm
by hazd31
As in title, need to mot the turd this week, got a few bits to do but most important is the front wheel bearings, i have brought a pair, but need a quick guide on how to fit them.
Can it be done at home? or am i best off taking the strut off and taking to down the garage?
Re: MOt time - How to fit front wheel bearings???
Posted: Mon Apr 16, 2012 1:27 pm
by Grrrmachine
It's not a big job. I've not done it myself, but the Wiki explanation is pretty simple:
http://www.e30zone.net/e30zonewiki/inde ... el_Bearing
Posted: Mon Apr 16, 2012 3:53 pm
by hazd31
Simple job, however i brought a 36mm socket, and it wont fit inside the centre :( do i have to turn the socket down on a lathe or what?
Posted: Mon Apr 16, 2012 4:25 pm
by Grrrmachine
It is a very tight fit; seems you need a slim-walled socket. Did you just buy (bought, not brought :) ) it specifically for this job? Still got the receipt?
Posted: Mon Apr 16, 2012 4:40 pm
by hazd31
yeh just purchased it, no reciept though, and i wouldnt need one tbh, there good as gold at the motor factors, im chasing up one off a mate, if not ill get this one turned down tomorrow!
Posted: Tue Apr 17, 2012 8:43 am
by Billwill
Make sure you do not pack the bearings full of grease....they should come with the correct amount of grease inside.....I learnt this the hard way when I was much younger! :wink:
Posted: Tue Apr 17, 2012 8:54 am
by e30topless
hazd31 wrote:Simple job, however i brought a 36mm socket, and it wont fit inside the centre :( do i have to turn the socket down on a lathe or what?
don't buy a hex 32mm socket, it won't fit :P
you need one like this..
oh and it's much easier to undo while the strut is on the car, the bearing is usually not too bad to remove and it's a really good time to replace the disc backing plate if yours is shot
Posted: Tue Apr 17, 2012 9:04 am
by Brianmoooore
I find the old bearing/hub can usually be pulled off by hand if you refit the road wheel after removing the nut, and pull them off together.
Posted: Tue Apr 17, 2012 7:09 pm
by hazd31
Yep was increadibly easy, soaked the hubs in wd40, machined my new tool down and they came off real easy, by hand, didnt need a hammer or to re fit the wheels :)
Was concidering packing them with grease, but fortunatly i was lazy!
Posted: Wed Apr 18, 2012 8:44 pm
by asmith88
my bearing practically fell out when fitting, couldnt ask for handier
Posted: Wed Apr 18, 2012 8:50 pm
by kolee
Mind if I ask where you got the bearing and how much you paid. Seen a mountain of them on fleabay and prices range from £15.00-£50.00.
Posted: Wed Apr 18, 2012 10:07 pm
by hazd31
kolee wrote:Mind if I ask where you got the bearing and how much you paid. Seen a mountain of them on fleabay and prices range from £15.00-£50.00.
£85 for the pair including vat from the motorfactors.
Posted: Fri Apr 20, 2012 11:15 am
by hazd31
Failed on rear subframe bushes and an advisory on driveshaft gator :(
Booked into a specialist as its cheaper than me mucking around for a couple of days!
I do need a decent drive shaft if anyone has one?
Posted: Fri Apr 20, 2012 11:18 am
by Duke137
hazd31 wrote:Failed on rear subframe bushes and an advisory on driveshaft gator :(
I have a pair :)
http://www.e30zone.net/modules.php?name ... c&t=217745
Posted: Fri Apr 20, 2012 12:29 pm
by mcbonio
Why are the rear bearings so different from the front? The rears are a real bugger to do, yet the fronts are easy in comparison. I'n guessing due to the parking brake mechanism being there the bearing can't be part of the hub.?
Posted: Fri Apr 20, 2012 1:54 pm
by Brianmoooore
Nothing to do with the parking brake. RWD is the clue.
Posted: Fri Apr 20, 2012 2:00 pm
by hazd31
Brianmoooore wrote:Nothing to do with the parking brake. RWD is the clue.
This is true, front ones on fwd are a lot harder than rear ones.
Posted: Fri Apr 20, 2012 3:34 pm
by mcbonio
I think as a whole older BMWs are pretty easy to work on. Everything is well laid out, enough space to get hands and tools in and not many special tools needed really.
I do work on my brothers Toyota Supra, everything on that is difficult and time consuming.!
