Adjust throttle plate - what am I doing wrong?
Posted: Fri Feb 17, 2012 9:04 am
Hi
I've adjusted my throttle plate as described in the Bentley manual: 0.4mm clearance between plate and wall at idle position.
However, to get the TPS adjusted correctly, I had elongate the holes in the sensor mount so that I could rotate the TPS enough for it to see the idle position. ???
Once adjusted, I checked it with a multimeter, and the TPS adjustment was fine. But now I've fitted it, the car idles way too high, like 1500rpm.
What have I done wrong? I used a 0.4mm feeler gauge (15 thou). Is this too much?
The reason I was messing with it is my car won't idle. I've spent hours checking EVERYTHING, and the throttle was the only thing that wasn’t as per the Bentley manual
Jim
Jim
